I just purchased a 2000 SWS II OX 66 FI (6G4 5X150TXRY) motor and boat with less than 100 hours. It looks and runs great but does not transfer oil in either mannual or automatic mode. I have boated for many years and am reasonably comfortable with a VOM but this is my first outboard. From the forums I have seen, I did some checking, but really do not understand enough about the system to know what I am doing. I assume the float switch in the engine tank will start the transfer pump if the level is too low and will shut it off when it is full. I also assume a float switch in the main tank will do something if it gets too low. I have 12 VDC at the main tank on the brown wire and appear to have no resistance to ground on the blue and black wires as well. Is there a way to simply check to see if the pump is bad? How is the pump replaced if needed? Any help I can get will be greatly appreciated.
Thanks, Ben
Thanks, Ben
