My outboard is having trouble running, i have gone over motor and did find that the priming bulb isn't staying hard and the fuel filter doesn't stay full. I have looked for an air leak to no avail. The motor surges when i can get it to run. Any suggestions. Dave
2000 250hp efi yamaha outboard running terrible
I have to push on the throttle sensor to get it to start and after i got it to run i was cruising but it wasn't running well. When i hit the trim switch either up or down the motor would take off like it was suppose to. As soon as i released the switch it would go right back to dogging. It does seem to be going thru alot of oil also. Dave
Originally posted by Tucker View PostSounds like bad LP fuel pumps. I believe you got 3.
At the dock in idle, are you dumping gas and oil out of the exhaust?Insufficient Fund$ II - 26' Paramount, twin Yamaha 150 HPDI's
Sometimes you eat the bear, Sometimes the bear eats you!
to isolate supply from motor , use an aux tank, hose and ball hooked to motor filter
need to monitor fuel pressure @ rail
done any service ??
I do have alot of gas leaking out. actually i found my trim and tilt os not working. I think my problem is electrial.
This is an OX66 right? What's the os? Don't think trim/tilt has anything to do with fuel delivery. You got a soft primer bulb, work from there. Use the aux tank like jb says; that should eliminate lots of things.1999 Grady Sailfish SX225 OX66
ÂÂÂÂÂÂÂ
