I just bought a boat with this 4 stroke Yamaha engine. Took the motor for a check up and the computer did not report any problems and only 425 hrs of service and 150 psi of cilinder comperssion. 100 hrs service was done, new impeller and new oil for lower unit were also replaced. The lead mechanic seems to think I may be experiencing the vapor lock issue but out here in California the water temp was 57 and 67 out in the water.I don't belive I have the heat+gas+vapor problem.
After so many complaints, all over the states has Yamaha ever addressed this issue??
What do you recommend I do next?
Thanks,
Thanks,
