This is the carb off of a '93 T9.9ELHR Yamaha Outboard
I mistakenly put the #35 6G8-14217-00-00 CHOKE VALVE into the recessed hole where the starter brass pipe (below the starter auto-enrichement valve) goes into -- The part choke valve became stuck and I couln't remove it. I also had the 6G8-14345-00-00 MAIN NOZZLE PLUG in the wrong location.. Take good note's or pictures when you take apart your carb for the first time! Some of the parts will potentially fall out too, so be careful.
