I Have a 1995 150 Saltwater Series. The power trim switch at the motor went bad and I replaced it with a new one. When I tried to use it, I heard an electrical crackle sound and now I get no power trim from there or the throttle and also no ignition. I checked al visible fuses and found all to be ok. Is there any hidden breakers or fuses?
Power Trim / Ignition Issue
Check the fuses on engine not the ones at battery. Check for shorted or pinched wires in control box where you replaced switch.
ÂÂÂÂÂÂÂÂÂ
