hi, new to forum and just wanting to make sure i am buying the correct part. i was having issues with the start switch and power T&T on my center console not working but the T&T on the motor was working fine and all battery connections were good. so i started looking for bad connectors and found one on the motor for the main cable that goes to the switch and T&T control on the throttle. i found this part # 688-8258A-20-00 want to make sure that is the correct cable to replace. this link (cable pictured as #3) ELECTRICAL WIRE HARNESSES - Yamaha - Yamaha Motor Parts - 688-8258A-20-00-WIRE HARNESS(10P5M shows exactly what the cable looks like that has the bad connector. is that the correct part # for the #3 cable in that link?
Thanks guys
Bill
Thanks guys
Bill
