Thanks for the information supplied regarding my last post, I have some new ones though. What is included in the single gauge kit (6Y8-WE83S-70-00)? Besides RPM, what else is monitored with this gauge? The longest main and main bus harnesses listed are 30 feet, I need them to be longer, will ordering a second harness allow me to plug two together to get the length I need? can the harnesses be cut and spliced? If I go with the single gauge kit can I add a second gauge in the future? Once again, thanks for your help in the past.
Command Link
The gauge displays rpm trim and more depending on 2 stroke or 4 stroke. It comes with the gauge, 2 buses, 1 wire from motor to bus and lead to power up the bus. Most applications don't require longer than 30 ft. The main bus wire goes between buses, you can make the bus to engine wire longer or the gauge to bus wire longer to fit your boat.
