2003 150HP carbureted OB stamped "150TXRB". SELOC Repair Manual lists 150A, C150TR, and other models with different prefix and suffix letters with different timing specs from each other, but none listed for my model. Year and HP rating suggest 9 degrees ATDC running, and WOT measured statically at 23 - 25 degrees BTDC. Actually reads TDC on timing light on cylinder 1. Adjusted the magneto control lever to move the timing from ~ 9 degrees BTDC to TDC but cannot adjust to ATDC at all. Idles rough about 700 RPM and does not really smooth out at increased throttle. Compression 115 - 120 all cylinders with engine cold. Still may have carburetor problems ( it has 3) but want to remove and rebuild carbs only if necessary.
Thanks,
John
Thanks,
John
