Hello,
I´ve been following this great forum from the Indian Ocean for a while. I just acquired an old 16 feet Boston Whaler (with 2 side consoles) equipped with a 2 stroke Yamaha CV85 outboard (end of the 90´s I guess) with trim & tilt but no controls.
I´m guessing that the original controls where side-mounted and much probably the 703´s. I´ve been therefore looking for these lately. However just today I came across the 6X- side controls, which would be perfect since it looks like the body can be installed within the interior side of the hull while the throttle control sticks out of it (=esthetics reasoning
). Is this correct?
Also, would the 6X- be compatible with my outboard, and if so which Yamaha cable should I use?
I read that the 6X- requires an ignition switch... Which one exactly should I get?
Thanks a lot and keep it up, this website is a wealth of knowledge!
