What parts - 200HPDI Preventative Maintenance
  • What parts - 200HPDI Preventative Maintenance
    Guys
    I am buying a boat with twin 200 HPDIs (2000 Models) . I am exporting it back to Australia and thought it would be good to load up on some spare parts/plugs/filters etc. as they can be a lot less expensive in the US.
    Could anyone provide me with a decent list that would cover conservative preventative maintenance and regular servicing for about 300 hours of use. The engines have about 680 hours on them and the timing belt and oil reservoir and pump replaced at 500.
    Thanks very much
    JT
    Lots of info here juz. Do a search here and on THT. Print it all out and make your shopping list.
      HPDI does not have a timing belt, no worries there.
      I would carry the correct spark plugs, only way to correctly ID which plugs you need is to look at the ign coil primary connector.
      I would take engine filters,VST filters and medium pressure filters.
      water pump kits,not just impellers.
      a few water pump housings, folks tend to start them dry.
      lower unit seals.
      lower unit drain and fill washers.
      pressure control valve grommets.
      thermostats.
      just finished catching up on the maint on a 225BETO , in Rio Chico VE.
      if you dont bring it with you you dont have it.
      fortunatly I have been stocking and training a tech there for about 9 years.
