I have a command link tach in the lock position after being installed. How do I unlock it?
Command Link tach
Not sure what you mean by locked position, when install you do have to complete the intial setup to get all functions working.
plus is Y-cop capeable.
dunno how but you could have triggered it somehow.
if you did trigger Y-cop take it to a dealer.
try to many times and it could permanantly disable the engine ECU.
myself I would double check the main harness connector at the engine for the command link buss,check the hub at the dash for correct installation of any devices.
devices being tachs,speedos,tri ducers and such.
the gray terminating resistor MUST be installed at the last unused buss port.
Â
