My 1987 ETLH 90 is exhibiting a speed drop issue and reverting to "safe mode"... yet the buzzer alarm is not sounding at the same time.
A couple of questions:
1. I checked the thermoswitch with the hot water dip continuity check, it was almost spot on so - that eliminates a bad sensor there. I heated the thermoswitch with a heat gun on low power while connected and it DID trigger the buzzer - as expected.
2. My oil reservoir is half way full and displays a green light, but is it possible the breather (I see they changed the design and eliminated this after 1988 in favor of a different design) on top of the reservoir is plugged and creating a vacuum and restricting flow, thereby triggering the speed drop function? The speed drop function is only supposed to happen when it has less than 0.4 qts in the reservoir, and the alarm is supposed to sound along with the red light displayed on the tach.
3. I recently rebuilt the impeller and have an impressive pee stream at idle but no psi reading. The display shows 5psi when I throttle up to about 2000 rpm but does not climb above that. Should I see a higher and higher psi on the gauge as the engine revs up? IF so I may need to revisit the impeller rebuild even though I feel I did it correctly - or perhaps the connecting water tube is not transporting all the water that it can into the head...
4. Do the buzzer and speed drop always go hand in hand - or is it possible to get one without the other?
Dang, I'm really stumped on this one.
Any direction here would be greatly appreciated.
Other than that, the motor runs great!
Picture of my "trailer on a toon" attached for your viewing enjoyment. It was named the "Y knot?"
