150 Tach Problems
  • 150 Tach Problems
    I was on the water yesterday, everything was fine until I was ready to bring it out of the water and I noticed that the tach over 4000 rpm was bouncing erratically. No change in sound on engine. Guage? Tach cable? Tach drive? Any way of testing? Thanks in advance.
    Check the wire connections (loose or corroded), if ok then the tach is probably bad.
