Multi function speedometer
  • Multi function speedometer
    Hi,
    I have a 1993 Grady White with a 1993 Yamaha 250. The multifunction speedometer and fuel gauge stopped working. The display shows nothing. The trim and tach display work, but the tach does not show RPM. Is there a trouble shooting guide and wire diagram that I can follow to determine if it is a faulty gauge or bad wiring?
    Should have battery voltage between red wire and black wire at speedo, should have battery voltage between yellow and black wires to all gauges when key is on.
