Have a Yamaha F15mshw (66M) manual pull start. Would like to upgrade to electric start with generator. Do you have a kit or required parts list. Looks like the (EH ONLY) series with horizonal starter bolts, bolt up to engine block not vertical to flywheel cover. Already has the geared flywheel, but not sure if it has the magnets embeded in it?. Not sure whats under the flywheel already. Could the coils under the flywheel "Pulse, Charging, Lighting be under there and not used? They show in the standard schematic. Would it already have the "Pulse Coil" for the ignition and don't need to buy another. Is the (EH ONLY) motor the same as the (MSHW) except w/elect start and generator? Where can I find a full electrical schematic of this motor?
F15mshw Electric start conversion
Would need number 1 and 11-13 on this diagram 1998 F15MSHW Yamaha Outboard STARTING MOTOR (FOR EH ONLY) Diagram and Parts
All parts on this page 1998 F15MSHW Yamaha Outboard ELECTRICAL 2 (FOR EH ONLY) Diagram and Parts
If already have flywheel with gear then all parts on this page for EH model except rotor, 1998 F15MSHW Yamaha Outboard GENERATOR Diagram and Parts
ÂÂÂÂÂÂÂÂÂÂÂ
