i have a 1999 200hp. its been sitting about 9 months. would not start.batteries dead. bought new batteries. now i get a rapid clicking with the trim and it will not start. similar clicking noise. help.
dkaelber
SX200TXRX, means its a saltwater series OX66 3.1L engine.
you most likly left off a ground wire at the battery.
the rapid clicking is the system trying to operate on a reduced current flow.
either your battery connections are loose or you missed a cable at the reinstall.
double check and post back
that rapid clicking is a sign of low voltage at either the start relay or the stater.
same with the trim.
some where a connection is loose or missing.
as the current draw exceeds whats avalible the relays rapidly drop in and out.
thats the clicking your hearing.
ÂÂÂÂÂ
