I'm rebuilding the water pump on my 1996 225 V-76 3.1 ltr. engines. Can I just buy the water pump rebuild kit, or do I need to buy the gearcase gasket kit, and the seals and gaskets for the top of the water tube also? When I did my 9 HP, all I bought was the water pump rebuild kit; but I don't want to get the engines apart and find I need gaskets not in the kit. Thanks
Impeller rebuild- V-6 225
prhnkp,
Craig is right - the water pump repair kit will have everything you need, except:
1.Yamaha shop manual to guide you and tell you torque specs and where to use thread sealer and grease.
2.Quality thread sealer - I use Permatex 14A with Teflon.
3.Marine grease
4.Torque wrench
Good luck,
Ken K
Â
