I have 2005 twin Yamaha F250s on a 30 CC . Boat came rigged totally with Livorsi gauges thus no fuel mgmt system . I dont want to go to the expense of the Yamaha guage options and am looking for experienced advice on another system that will work reliably with these motors. Any help appreciated.
Fuel Management on F250
Might check on the Flow Scan products. We don't sell them but see a lot boats with them.
Attached is a link for you. Look to see if you have the wire harness on your motor that is show in the link, if you do then you can do the NMEA2K setup. Some late model 2005 4 strokes were manufactured for command link or whatever the wiring needed is called. The link will show you the the connector to look for.
Sorry, did I post without attaching the link!!!!Here it is!
ÂÂÂ
