I had a pod built for the above engine. I am unable to measure the center to center top mounting holes as the engine is frame mounted in an awkward position. Anyone know the center to center distance and the correct hole size. Once these are drilled I can mount it on the pod and drill the lower holes.
Bryan
Bryan
