2005 F250 V6 guages
  • 2005 F250 V6 guages
    I am fitting a new F250 V6. Where does the water pressure hose with brass connector connect to the engine? Also can you advise where the oil pressure hose from the tachometer goes on the engine?
    It's hard to explain without showing you, but the water pressure fitting is behind the rear plastic cover on engine. If you look at the parts listing in the online parts catalog under F250TXRD and go to "Cylinder crankcase 3" page, referance # 26 is where the water pressure tubing is installed remove the bolt(ref. # 21) and installed water pressure fitting. There is no oil tubing from tach, the oil lights in tach are connected through wire harness.
