Hi, my yam f80 (Carb'd) is making a popping noise throught the air filter above idle? i have adjusted the throttle sensor switch? what is the cure ?? reguards Graham
yam f80
mixture screw
how many turns would i turn the mixture screw out?? its currently at 2 3/4 turns out the popping is not constant ,so i think the inlet valve could be ok ??? Graham would you recommend petrol for the leak down test, and at tdc on all cylinder individually, many thanks for your invaluble advise Graham
f80 carb problem
ive got it running sweat now, stripped the carbs blown them trough with air line ) just need a run out on the water now
before it was'nt revving above 3000rpm with out spluttering and popping and fading ,fingers crossed all is well now?? a big thanks to the yamaha forum
ÂÂÂ
