I have a 1994 Yamaha outboard T9.9ELHS. It is a 2 cylinder and I am throwing parts at it to try and solve a stalling problem. Mechanics that I have talked to have all mentioned that I should change the spark plug wires. So, I tracked down the part on boats.net and got a quote of $47.70 per spark plug wire. This is incredibly high priced since I could buy a whole set of spark plug wires for a V8 for less than $50.00. I ordered 2 plug cap assemblies at a coat of $109.00. What, are they made out of ****!
**** Coated Spark Plug Cable
The Yamaha plug wires and caps are very high quality and rarely fail, so you may have wasted your money on those, but at least you have a spare set. Your stalling problem is more likely a fuel related problem, tank, pick-up, fittings, fuel pump, filters, carb. Have your carbs ever been cleaned? Good Luck!
