I have a cold starting problem. The motor will start when cold if I hold my finger over the air intake and run on high idle as it should. After the normal time motor comes to normal idle. It seems as though the thermal valve is working, but the carb doesn't get the choke affect. I have taken the valve apart and can't see a problem. Also I have dissembled the carb and cleaned in carb cleaner. All jets are clean.
Any help would be appreciated.
