Power trim/tilt
  • Power trim/tilt
    Hi all,
    Please advise how can I change manual release screw ? This one is damaged om my motor (40hp ETLD)
    Thank you
    Assuming it's seized. Yea, know what you mean, mine was really tight, screw driver slot was worn. I had luck putting the screw driver in the screw and taping it with a hammer and it freed up. Haven't done the other one yet. If you got it loose all you need to do is take out the circlip and it should screw right out.
      Thank you for info
