Diital Tach - will it read prior hours?
  • Diital Tach - will it read prior hours?
    I have a 2005 90 TLRD. If I buy a yamaha digital multifunction tach, will it show the hours i've previously put on the motor?
    Also, if i'm replacing an analog tach, is it a direct replacement (i.e., simply disconnect the analog & plug in the digital), or do i have to replace the wires...i guess since i have no hour meter now i'll have to at least be adding wires...
    ...basically is it something most folks can do themselves or will i most likely end up spending $$ to have my dealer install it
    thanks all
    2005 Xpress HD18CC
    2005 Yamaha 90
    Rooting for the Yankees is like Rooting for the House in Blackjack
    depends on the analog tach your replaceing.
    if it had the oil and overheat visuals then the trim/alarm harness is there. if not you need one.
    no the hours will start at 0 but its all part of the basic tach wiring.
    can ya plug connectors together?
      Student discounts
      Student Discounts
      [url=http://www.studentbasecamp.us]Student Discounts[/url]
