2 of the stator wires were .4 OHM
1 was .8 OHM
Green to ground infnity for all.
Does that signify a bad stator?
Does the stator put out voltage I could test?
What should the voltage be leaving the rectifier?
Its not a blown fuse cause it will charge, just not as strong as usual.
Thank You
1 was .8 OHM
Thank You
