change a TUR to TXR
  • change a TUR to TXR
    Hi from Greece!
    I have a yamaha engine LF225TUR and I must take off the extension so as to transport the engine to LF225TXR. I want you to inform me about which parts I must order so as to fix it.
    Thanks in advance and I am looking forward to hearing from you the experts.
    Regards,
    Giannis Tsabas.
    shift shaft and drive shaft if it has the removable 5" extension.
    simple, yet expensive.
      Do you know the exact parts which I 'll need ( or their code numbers) and how much they will cost?
        can you tell us if its a one piece midsection or is the 5" extension two part?
        could be either way.
          what about the water tube? I would think that is something that needs replacing also. and does that require pulling power head to install?
            depends on the mid section.
            some were 2 piece some were 1 piece.
            some of the U models,30" shaft, were modified X models,25"shaft.
