Prop Suggestions
  • Prop Suggestions
    I have a 2006 Pathfinder 22 foot TE with a 200HPDI (150 hours). It cavitates when coming up hard out of the hole, max RPM is approx 5750 at 47mph and everything is tweeked. The extra weight on board is a ttop, powerpole and 101 *****ing motor (36 volt). I do not know the prop size now. Can anyone suggest a starting point on what to try? I am buying a new prop (i guess because I need this fixed). Any assistance or advice is greatly welcomed.
    Rick
    571-723-3458
    you need to pull and read what prop you have on it now, RPM s don't sound that bad to me. may need to look at your set up or style of prop
    You can look at this site to see what they were running on a rig like yours.
    Performance Bulletin Home
      your prop sounds fine...do you have fins on the foot?? also make sure it is trimmed down and also check and make sure your motor is not too high..
