flesh mount side control box
  • flesh mount side control box
    Ok maybe I wiil ask this question.
    What is the part number for a flush mount side remote control box that will work with the conversion kit and harness listed below.
    60-R-G8501-00-00
    69-G-82590-00-00
    Or will I have to have a different kit and harness for a romote flesh mount.
    I have seen on the walleyecentral site that a conversion of a T8 used a part number starting with 705.
    Any help would expedite my purchase of the necessary components to complete this job before the water softens up.
    Thanks..Tom.
    What ever you do, do not mount a control box to your flesh as it will hurt very bad.
    Sorry i could not help myself, and I do not have the answer to your question.
      out of memory I cant tell you.
      the 705 is a flush mount,the 703 is a side mount.
      the reason for the memory lapse is some small engines used a push to open throttle and others used a pull to open.
      the part number of the box will be based on which way your throttle linkage moves.
        Thanks rod that helps a little, and 99yam40 ur funnier than a one legged man in a butt kicking contest.
