ALARM/GAUGE ON WITH ENGINE OFF
  • ALARM/GAUGE ON WITH ENGINE OFF
    I have (2) '03 150's that run great, but when starb. engine is turned off, it's main gauge stays on and sounds an alarm only with key off. The alarm will reset when turning main power off/back on, but gauge stays on with key off.(Port is normal)No alarms with both engines on.This has just started. Any help would be appreciated.
    From keyswitches,check the harness that powers the gauges, the 4 wire,R,B,Y,G. Try switchin the harnesses to switches to isolate poblem.Could be a faulty keyswitch IF no work has been done lately under dash.
      Dale,
      I would agree with JB in that it sounds like a faulty ignition switch.
      Good luck,
      Ken K
