2010 60hp four stroke wiring
  • 2010 60hp four stroke wiring
    tring to hook up a new 60hp four stroke to controls for a 2004 50hp four stroke all the plugs match except one looking for wiring diagram for both controls and engine
    They are the same wiring except for the trim/oil harness connection to engine that operates trim gauge and warning lights in tach, if have Yamaha Digital Tach. Would have to install 6Y5-85335-00-00 Adapter harness at between tach and wiring harness, only one of the off white colored square connectors will be connected to engine.
    Or install the new tach kit, 6YR-W0035-E2-00.
      Harness worked great
      Know I need a manual for a 2004 multifunction tach if one is avalible
