I just replaced my fuel filter and now, can't get the primer bulb to prime...I removed fuel filter, filled w/gas and tried again...no prime. Replaced the primer bulb - still not priming.
Please help!
try holding the bulb with the flow arrow pointing at the sky.
also if the carb bowls are full then no more air or fuel can be pushed through,same with an EFI vapor seperator.
thanks for the reply! I tried taking the gas line off the bulb that runs to the engine - holding my finger over the nipple that the engine gas line would be connected to after squeezing the bulb...squeeze - hold, etc. didn't take but a few times and it was tight. I haven't ran it yet - I'll probably have to pump the ball again but I think that's got it.
Hope this helps someone else in the future!
