I have lower unit lube leaking out around my prop? What part do I need to stop this?
Lower unit lube leak
Remove prop to inspect and confirm that it's your prop shaft seal leaking, check for fishing line wrapped around prop shaft and under seal causing leak/damage to seal. You may need a special carrier puller to remove and replace prop shaft seal. Maybe get seal replaced at boat/motor shop if unable or unwilling to attempt it yourself. Good Luck!
