G'day all,1st post noob. I'm converting my tinny from tiller steer to side console and I'm a bit unsure of the bits I need. The motor is a 1999 Yammy 25 cv ( single carb) pull start. Should I use the 701 control box or the 703 ? The control cables will have to be pretty short, about 1750 mm - do you order these to length or can longer ones be cut down ? I would like to keep everything Original equip if I can. Any help would be great
Cheers.
Cheers.
