I've got at 2000 F80TLRY and its leaking oil down the lower cowling. I don't see any in the bottom of the engine when I take off the upper cowling. Does this sound like the oil seal at bottom of the crankshaft? Other than the oil pan gasket, what are the other seals/gaskets that could spring a leak?
No water in the oil, drained that today. I do have a yamaha manual and I'm looking for the most likely fix. I just fixed a problem with a fuel vent that allowed water in the tank twice. Could any symtoms of this cause the oil seal problems (vibration, overpressure...)?
Thanks in advance for any help.
