First off, this post may get a bit winded while I try to explain my situation..so sorry in advance.
I have a 1990 Yamaha 115hp outboard and a Yamaha 703 Remote Control Box. Sometimes the motor will go in reverse and most times it will not.
When it will not go in reverse it makes a "grinding" noise because the "teeth" are not meshing. When I turn off my motor and put my control arm on my control box full forward and full reverse, then put it back in netureal and start the motor, it sometimes will go in reverse, but not all the time.
Also, when I shut the motor off and turn the prop with my hand, you can feel a "click", like the motor is not fully in netureal. This problem is solved by moving the control arm back towards the reverse postion maybe an inch.
I am thinking that it make be a linkage issue or maybe the control cable has to be adjusted. Can anyone tell me if indeed this is my problem, and if so where and how do I make the adjustments.
