Rectifier Regulator
  • Rectifier Regulator
    Hi, I have a 2003 Yamaha 30 HP CV outboard, would like to install a Rectifier Regulator so I can power Nav lights, chartplotter etc. Would you have the part number of the Rectifier Regulator I need? Searching only seems to find a 25 Hp or a 40 Hp or 4 stroke. My outboard is 2 stroke. Is it easy to fit, I was jst going to run a cable directly and by pass the socket on the outboard as my outboard is fixed and the cable will not need to be unattached. If you could help I would be grateful. Thx
