On the Yami 225 how do you check your trim fluid levels. Is there a simple way or is it best for a dealer to handle? I only see 1 cap and is mid level and would seem as though fluid would pour out if opened? If I check it do i need to bleed the lines after?
225 Trim Fluid Levels
