Older 1991 703 Control question
  • Older 1991 703 Control question
    Hello
    I recently picked up a 1991 90tlrd 1991 90hp two stroke. It's actually missing a lower and the control was cut from harness. It looks new under the hood, does not seem overhauled in the past. I was told it had low pressure in a cylinder. Long story short figure I need to send some power to it to get a compression reading.
    What I'm trying to do is locate a harness. Ive seen plenty 10 pins with a plug both ends. My original harness had individual push connectors for each wire in the control box. Was wondering if I could use one of the double plug type units and just cut and wire for the push connectors. Or is there a different model harness I'm should be looking for?
    Thanks in advance
    Number 49 in this diagram is the harness you need Yamaha Outboard Parts 2005 OUTBOARD RIGGING PARTS BREAKDOWN CONTROL STANDARD SIDE 703 PUSH Diagram
    Or you can cut the end off a 10 pin main harness and rewired it.
      That looks like the right one. I looked it up and can find them online but no description.
      Any idea how long they are??
        They are 16ft long.
