f115a engine trouble warning
  • f115a engine trouble warning
    engine trouble warning indicator came on twice today
    which one? oil or overheat?
      the one at the top, shaped like an engine block
        Check for water in fuel filter on engine(2006 and newer motors had water detection sensor).
          f115 engine warning light
          2003 model,no water present.i have an in line water trap in the boat as well with a glass bowl which i checked at the time.oil level good and spark plugs good:
            If didn't get an alarm or rpm reduction then probably a problem in tach.
