Hi I just purchased a 2004 yamaha 0x66. I need some help with rigging i have a 1997 Hydra sports ocean skiff cc. that was equiped with a 200 Johnson. I need the Part numbers for oil tank, and controls. Will the omc gauges work with this engine? or will i need yamaha gauges also, tach, wiring etc. I anyone has the part numbers for these items and some info on the gauge compatability would be greatly appreciated. Thanks.
2004 200 ox 66 rigging
If you need binnacle controls the use
6YR-W0035-93-00 Oil Tank assy
704-48205-P1-00 Single Binnacle Control box
(2) MAR-CABLE-xx-SC(replace xx with length cables needed) Control Cables
704-82570-08-00 Switch Panel
6X3-8258A-00-00 16ft 10 Pin Main Harness
or 6X3-8258A-10-00 20ft 10 Pin Main Harness
or 6K1-8258A-40-00 26ft 10 Pin Main Harness
or 61B-8258A-01-00 31ft 10 Pin Main Harness
The OMC tach may work if has a 12 pole alternator setting, OMC trim Gauge wont work and OMC engine warning lights wont work on Yamaha engine
You can use
6YR-W0035-E1-00 Multifunction Tach kit which has rpm's, trim gauge, hour meter and warning lights
Mechanical gauges
Can you tell me what the mechanical tach and trim gauge part numbers are and wiring harnesses if needed. the tach with the oil and water alarm. Thanks very helpful info.
Yes you have a couple of choices
6Y7-83540-80-00 Pro Series II Tach with warning, Black Face
6Y7-83670-40-00 Pro Series II Trim Gauge, Black Face
68F-82553-70-00 Trim/Oil Harness
6Y5-83553-N0-00 Gauge Power Harness
6Y5-81950-00-00 2 Stroke adapter Relay
or
6Y7-83540-90-00 Pro Series II tach with warning, White Face
6Y7-83670-30-00 Pro Series II Trim Gauge, White Face
6Y5-81950-00-00 2 Stroke Adapter relay
ÂÂÂÂÂÂÂ
