I have a 2000 100hp Yamaha 4 stroke. Both batteries check out excellent. My problem is motor does not turn over fast enough to start. Also drags down batteries. I pulled the plugs and it turns over faster but still slow to me.
Starting Problems
Pull starter and have a starter rebuild shop check it out, I have also seen start relays with burnt contacts not making good contact internally, if that is not your problem then you may have a major problem with the motor internals.( bearings or pistons)Last edited by 99yam40; 12-26-2010, 10:12 AM.
