Trim Problems on 4 Stroke 150
  • Trim Problems on 4 Stroke 150
    Hey, everyone, having some serious problems with my trim on my 150 outboard. The motor is running, but it is stuck in the 'up' position. What is the best and most cost effective way to solve this problem? Thanks so much for your quick response. The motor trim as well as the throttle trim will not allow it to move to either position...
    Are you saying that the trim and tilt motor runs but the rams do not move ?
    If so did you make sure the tilt lock is not in place holding motor up?
    if that is not the problem then try releasing the manual release to see if that will let it down. Then close back the manual release and try bumping the trim switchs up and down to see what it will do in both directions.
