Connecting a lowrance hds-7 directly to the command link on the new 2010 f-250 motor. Will that give me the same type info as if I had installed a EP-60 Fuel sensor. Key info wanted is Gallons used since last re-set.
its already part of the commandlink speedo.
from what we have found commandlink is a recieve only device and wont transmit engine data.
Ill know more when I get done with this F300 4.2L we just rigged.
