Can I get all parts to get this fixed. Oil is leaking right through the wiper seal. Looks to me that I will need to remove the motor. If so how do I go about starting this project. Lower unit is off right now for another issue.
90hp tilt tube ram leaks and bad dust seal
May be able tilt trim unit out enough to remove trim ram, here is link to parts diagram Yamaha Outboard Parts 2000 90TLRY POWER TRIM & TILT ASSEMBLY Diagram
Can I just remove the lower bolts with bushings
remove the pin at top and it will come out? The diagram only shows rod,sleeve,two bolts. Are those bolts at front easy access. Update I put 2x6 on back, removed steering arm,pin and tilted it back. Does 10mm oil fittings go lefty loosy righty righty? Does there look to be enough room to pull ram out. Now I need the yammy toolAttached FilesLast edited by 200090tlry; 12-18-2010, 02:32 PM.
Â
