Need complete list and a how to to connect the new motor to the existing Lawrance HDS 7M, Boat is a 2005 Sea Pro and does not have any NMEA cabling. Currently I'm Using a analog guages. I'm wanting to clean up my dash. How many of the guages can I replace?
Yami F250 TXR NEW, to Lowrance HDS 7M
Here is the information on Yamaha's Gateway module that connects to Yamaha's Command Link system and to NMEA 2000 network, you would need to install the Lowrance Network and install Yamaha Command Link network to engine.
O2009_014.pdf
I guess at this point I go to Lowrance to get the balance of parts needed ala NMEA 200 network?
The engine has to be 2006 or newer to be Command Link compatable.
ÂÂÂÂÂÂÂÂÂÂÂ
