Can anyone tell me how to check the power trim oil level for a 2000 Yamaha 50 hp T50TLRY outboard. I removed the entire assembly to replace the motor brushes and would like to check the oil level while it is on the work bench.. I have attach the schematic breakdown for the power trim unit..
Power trim & tilt assembly- T50TLRY
With the tilt cylinder extended all the way up, remove reservoir plug(number 43) and fill level full.
ÂÂÂÂÂÂÂÂ
