alarm buzzer
  • alarm buzzer
    I have a 2002 130hp motor with 300hrs with an intermitent problem
    After driving the boat for 10-15 mins the alarm sounds
    I switch off and can start back up within a couple of
    seconds and can run for another 10-15mins or longer
    It seems to be worse when the engine revs are above
    4000-4500revs
    I have changed the water pump, spark plugs, fuel seperator,
    fuel filter
    Any thing else I can do
    Many thanks
    what alarm is it? oil or cooling?
      Its a continuous alarm that cuts the engine revs
        you need to find out if it is oil level alarm or a over temperature alarm.
        Try checking the oil level while alarm is sounding to see if it is low.
        As far as temp goes you could have a bad thermostat or bad temperature switch.
        pull them and test in a pot of water as you heat it to see what temps they do there thing
