Will a Carb Syncing Tool work on most outboards?
  • Will a Carb Syncing Tool work on most outboards?
    This might be a dumb question, but I am wondering if a Carb Syncing Tool will work on most outboards (like a compression tester), or is the tool manufacturer specific?
    -Banjo
    Generic tool. Basically a manometer. You can make your own.
    Stanley Islander 19, 2006 Yamaha F150TLRC. Ottawa, Canada
    16' York River, 1986 Yamaha PRO 50.
      home made?
      $1.55 Carb Sync Tool by Marty Ignazito
      Something like this Billy>?...is this practical...
        probably would work, but most 2 stroke outboard carbs do not have ports to hook them up to and a 3 or 4 cylinder would be real interesting to get balanced with that one
          Yam... How else would u suggest I sync three or four cylinder engines. Is there a better tool ? And I guess your right about trying to sync three carbs with only two ends. Or would it be that hard? Could I sync two, mark the placement on yard stick then simply move the tube to the unsynced carb and adjust to the mark?
          -banjo
            Are you talking about 4 strokes or 2 strokes?
            They sell manometers for syncing 4 strokes, but like I said where do you plan on hooking a 2 stroke up at? There are no vacuum ports to plug the manometers to.
            Follow the manuals steps to sync the carbs.
              Whoah..... Ok ok!........ Sorry for being the newb.... I'll look in my manual lol.
              -banjo
