Water Separating Fuel Filter
  • Water Separating Fuel Filter
    I am installing new Yamaha 10 micron fuel filters with the
    stainless steel heads.
    I will need to install elbows and other fittings
    before the fuel lines.
    What type of thread sealant should I use on these parts?
    Thanks.
    ive always used teflon tape and never had any issues
      pipe connections
      try using the black pipe dope as much as posible with e10 gas
      teflon breaksdown finer and can cause proplems down the road
        Thanks,
        While looking into this question,
        I also read somewhere that Permatex
        makes a product called Aviation Form-A-Gasket No. 3 Sealant,
        and that this is good for fuel line connections.
